Yeah both halves but a bit heavier than Dremill , Dremill be ok Ali , but steel ? Any adviceDremel and cutting disc.
Assuming you want both halves.
https://www.screwfix.com/p/erbauer-stainless-steel-cutting-discs-4-115mm-x-1-x-22-2mm-10-pack/111jrYeah both halves but a bit heavier than Dremill , Dremill be ok Ali , but steel ? Any advice
and the results were?Btw the way have tried big to small to medium to in between , its steel
It's all swimming around in my Gene Pool at Mo but may gel at some point ?)Looking forward to the project photos.
No cables aestheticsand the results were?
is this a project to get internally routed cables, if so i think you may be approaching it from the wrong side....
You'll get some , may end end up in one of that damien duffy art at some pointLooking forward to the project photos.
Why grinding discs when cutting discs are required. They're thicker by a long shot.Im experimenting with grinding discs before I sand them
