To the OP: The rake previously achieved by bending the steel forks is now accomplished by forks coming out at an angle from the crown. So the resulting geometry can easily be the same. As for the cushioning supposedly achieved by the bends - some people insist that a traditional steel forks does NOT flex in the bends when ridden. Instead, all cushioning occurs due to the steerer tube flexing. Or some such. This was discussed ad nauseum in the rec.bicycles.tech several years ago when it was still usenet rather than a google group, maybe still is.
Me, I ride old steel bikes with gracefully bent steel forks, simply because they look pretty. And have a Bates Cantiflex with a Diadrant forks hanging in the basement, waiting to be built up
Hi samid. Toronto,a wonderful part of the world. A lady friend of mine has family in Kingston and friends in Toronto. The CN Tower is awesome.
We are due a visit back,hopefully in The Fall and before the weather turns.
A very good friend of mine back in the 60's rode a Bates;can you begin to imagine the looks never mind the comments with my Curly Hetchins and his Bates out on the same run ?.
I wonder if anyone has asked the Prof's of cycling & engineering technology how a steerer tube that is only 130/145mm long and secured between the upper & lower races can flex ?. The fork blades are brazed into the fork crown lugs,any flexing of the blades would be absorbed by the union of the blades/crown. Even with the modern lug-less steel or aluminium fork the arch top to the fork blades meets the steerer tube on a weld,that tube is passed through the double wall of the fork arch. It that short length of tube coming out of the arch that carries the brake caliper.
The carbon fork on my Claud is enclosed at the point of the steerer endt,with only a small diameter hole beneath. The brake caliper is secured through the double walled arch/steerer tube concealed end.The steerer is still between upper & lower races,how can it flex?.
I used to notice how much forward & backward flexing the older curved fork blade did in cobbles in the 60's. I used to ride 14miles into work,there was a 1 mile stretch of cobbles that made some of the Paris-Roubaix cobbles look like a skating rink,I kid you not. Smith Street/Great Homer Street,Liverpool was notorious for the cobble lined pothole effect that graced the surface.
We also were privileged to have two very steep gradients near by that in the early days were also cobbled,they were Fairy Street & Haverlock Street. Haverlock Street was steeper than Fairy street (only just),it was necessary to put hand rails up like on a staircase. Fairy Street was conquerable (just),but Haverlock Street was a 'Chain Breaker'.
