Gixxerman
- Market Rasen
I was in the process of putting the MTB in the back of the car Saturday night ready for the BikeMania Challenge event the following day, when I noticed that the front tyre was flat. So I had obviously pick up a p***ture last weekend when I last rode it. Must have been near home as I didn't realise on the ride.
Anyway, tyre off and pucture found, and culprit thorn removed from the tyre.
Went to put the patch on. Opened the rubber solution tube, which quite full as I have only used it once before ages ago. Only to find that all it contained was air. I squeezed the whole tube out, but not a drop came out.
So where did it all go? The tube cap was on and tight and I have no reason to suspect that it wasn't air tight.
So I had been carrying round a tube of solution that was no use for ages now. Good job that I also carry a spare tube, else a p***ture in the middle of nowhere would have been disasterous.
I fitted a spare tube and completed the event.
So can rubber solution evaporate?
Should I replace the solution at regular intervals? If so how often?
