EckyH
- Nottuln, North Rhine-Westphalia
Hello,
probably this will be one of the daftest projects ever but as a quirky bicycle nut I have a reputation to lose.
In my head there is a Brompton shaped thought: the Brompton for Racing or Bracington.
When it comes to road racing bicycles then I'm a steel frame square taper bottom bracket rim brakes classical rims hubs and spokes derailleur gear guy.
That's why the base of that bike will be either a C line or an A line equipped with a S-type stem or a P-type stem if I can find one - or perhaps a predecessor of the C line.
At the moment I'm unable to decide whether it will become a singlespeed bike or with a 4 speed derailleur.
Rumours said that the 2024 C line will get 12 speed which probably means the combination of a gear hub and the 4 speed derailleur from the P and T line.
Hopefully the 2024 models will be announced soon, in particular the C line. The 4 speed derailleur seems to need an other mount on the chainstay than the 2 speed derailleur of the current C line.
If the rumours become reality, then the new C line frame will be the most flexible but also the most expensive option. Here in Germany we have a scheme where the costs for a bicycle used to ride to work reduce the taxes you have to pay which makes the bicycle significantly cheaper for me.
If the 2024 C line will not have the 4 speed derailleur, then I'll search on the used market for older Brompton bikes.
Somehow or other: one day there will be a Bracington. I'm curious how it will be...
E.
E.
