[as posted elsewhere]
Unfortunate timing, eh! But there are other press releases from last year, which confirm it's genuine.
You can do a 50m climb in 500m (i.e. a 1 in 10 hill) and then your capacitor is empty, if I understand this image correctly:
(source:
https://pi-pop.fr/index.php/faq/)
You then recharge the capacitor slowly over the next xx Km of flat/downhill riding.
In other words, you have quite small storage capacity which you must refill as you ride, and it can be released on the next climb.
For unfit people, this is not going to work unless you can pre-charge the capacitor at home before you start off, and even then it depends on where you live. (It isn't clear if pre-charging is possible on their website, but maybe I missed it.)
It may be OK for partially fit cyclists who need a little help up the hills, but still have the leg power to recharge afterwards.
There's also the problem of efficiency - regeneration is great but it's suggesting >80% in the above image.
That feels optimisitic, but from a very quick flick through some online research papers suggests that's realistic - or may be with the right design/materials.
I think this solution will just exacerbate range anxiety - you're continually one hill away from losing all assistance, and having to push a heavy bike.
The judges say:
- Nil points
