buddha
I now regret buying a Lidl track pump (a few months ago).
Pressure approaching 100psi, starts to hiss at the base. Then the top half explodes off from the base like a rocket
It turns out that the lower half of the pump (metal tube) is GLUED to the metal base. And the glue gave way.
I had to go out, so bodged it with some 'No-Nails' and a screw drilled through the base - but am getting a proper track pump now.
It turns out that the lower half of the pump (metal tube) is GLUED to the metal base. And the glue gave way.I had to go out, so bodged it with some 'No-Nails' and a screw drilled through the base - but am getting a proper track pump now.
