The chain lubrication maintenance method formerly known as The Mickle Method.
The "Old Rag Method". Being an old method which requires a rag.
You’ll never find a rusty chain on the bicycle of a ‘proper’ cyclist. One of the first things we learn about bike maintenance - after the importance of keeping our tyres pumped up - is that ‘oiling’ our chains is essential for pedalling efficiency and transmission longevity. Most general-purpose ‘oil’ is free-flowing but not tenacious so it will end up on the hall carpet, and is incredibly sticky if you throw dirt at it but cannot cope with high loads. It is oil. It is not as bad as rust – but it’s categorically not cycle chain lube. Most multi-purpose aerosols have very low viscosity which renders them too light to provide any long term molecular barrier between surfaces and washes away at the first sign of rain. One particularly well-known brand is (in spite of the manufacturer’s claims) designed for Water Displacement and shouldn’t be in the same room as your bike. It’s good for getting sticker glue off. It’s not a chain lube. Cycle specific chain lube is formulated to be tenacious, to stay attached to the surface of the metal but not so sticky that dirt is attracted to it. Also free-flowing, so it can get to where it is required by the process of capillary action but robust enough that it’s not easily displaced by the enormous pressures found within a chain under load. Lubrication reduces friction and wear between moving surfaces. The only chain surfaces which move against each other are on the inside - because as a section of chain arrives onto a sprocket the sideplates and rollers stop moving. Knowing this we can conclude that a chain doesn’t need lube on its outside surfaces. It won’t achieve anything there except attract grit and dust. The horrible black gunk which accumulates on the exterior surfaces of your chain and eventually smushed all over your jockey wheels, chain rings and best trousers is composed of grit and dust from the environment, mostly flicked up by the front wheel, mixed with the chain lube you left on the chain last time you lubricated it. Adding more lube to this mess results in more mess. To make it even worse: Lube + grit = a really effective grinding compound which is eroding your chain - and a worn chain will set about demolishing your expensive chainrings and sprockets with every turn of the pedals
You can remove your chain and soak in a solvent to get all the gritty cack off. A jam jar full of petrol/ paraffin/ white spirit will get it all off and can be helped along by a bit of agitation. Lots of companies make dinky little solvent baths with spinning nylon brushes which you can hang off your chain. I’ve used them all, and never found one which didn’t spray black solvent all over the shop. Using solvents to remove the accumulated cack certainly works but has the unavoidable downside of also removing all the lube from inside the chain. And … you now have a chain full of solvent – which you need to remove because if you apply fresh lube onto a chain full of solvent it will destroy the lube. So you wash the solvent off with - presumably - soap and water which leaves you with a chain full of water. Either leave it hanging for a few hours on a radiator or pop it in the oven? Who can be arsed? And let’s not forget about the contaminated solvent – which must be disposed of safely because solvents are terribly bad for humans or anything else that lives and breathes.
There is a way of getting chain lube into a chain without leaving it a sticky grit magnet on the outside It’s remarkably quick, easy to do and requires nothing more than chain lube and an old rag.
Preparation: Purchase a bottle (not an aerosol) of Proper Chain Lube of the kind manufactured by Finish Line, Pedros, White Lightning, Muc-Off et al and sold in your Local Bike Shop.
Step 1. Wipe the chain. Use the bike’s freewheel mechanism to your advantage (if it has one) by grabbing the lower run of chain with the rag and dragging it backwards, slide your hand forward and the chain will feed backwards through the rag presenting a new section to wipe. Wipe, wipe wipe. Rotate the rag to get a clean section every so often. Eventually, depending on the mankyness of the chain, you wont be able to get any more off.
Step 2. Now, lube the chain. With one hand slowly rotate the pedals backwards whilst dropping lube onto the lower run of chain in front of the rear mech (or wherever). When you are happy that every link has a drop of lube spin the pedals backwards a few times to allow the lube to seep in.
Step 3. The last thing you do is wipe, remember you don’t need any lube on the outside of the chain (aside from a very thin smear to discourage corrosion). You spend very much more time wiping than lubing. When the rag stops picking up black crud the job is done. Except just one thing,
Step 4. Ride the bike a few miles and wipe it again. And wipe up any excess that's found its way onto chain ring or jockey.
The more often you do it the cleaner your chain will be - and the cleaner your chain is the quicker the job. So little and often is better. Once a week when it’s dry is more than enough, more often if you do lots of miles in the rain. So wipe, wipe, lube, wipe, wipe, wipe. Ride it a few miles and wipe it again. Once your chain has become accustomed to the new regime it should take no more than a couple of minutes each time. Please note: The Method is for chain maintenance – for keeping a chain in good usable condition for its lifespan. It’s not an effective method of rescuing a severely manked up chain. Start with a clean or new chain for the best results.
Chains are consumer durables. They wear out. Better to replace sooner than later. Buy a chain checker – it’ll pay for itself before long. Sprockets and chain rings are only eroded by dirty or excessively worn chains. They’ll last for years if you keep your chains clean and replace them regularly. The notion of replacing your chain and cassette at the same time is a cycle industry scam designed to make you spend more money.
Mickle
Gunk
Oxford
Interesting post.
I’m fortunate to have access to a Rozone Degreaser, so I periodically remove both chain and cassette at home, take them into work and bring them back home both looking like new. I then lightly oil the rollers and wipe off the residue, consequently all my bikes have almost immaculate chains and cassettes. Agree about the chain wear tool, I check all of mine regularly
silva
Belgium
EHM!
Bicycle chain parts form an "open" structure.
An open structure = no build up of (here: oil) pressure possible.
Therefore, there is nothing that pushes back oil that has been pressed out by surfaces that contacted eachother due to transmissioned force.
Oil can only return (during the idle part of the cycle) by gravity and centrifugal force, on condition that these are strong enough to move the fluid/oil. A "thick" oil requires more force, a thin oil less.
So a viscous oil, ie a "thick" oil can prevent the oil returning, and without returning, no oil at the next load cycle, ie, no lubrication.
"Viscous lubricants" get pushed out during the first cycles and finito lubrication.
For an open construction - chain, it's like a contradiction in two words.
ABOUT CLEANING CHAINS!
Other methods have 0 downto - mechanical results.
If I'd say 1 thing to do: prevent water on the chain.
Because its viscosity is so low that it sneaks in deep/everywhere, to there cause rust, because air has an even lower viscosity.
And that internal corrosion is way worser than transmission forces and frictions.
Since it makes steel expand > rough.
Take a corroded but dry chain. Tension the chain and do a ride.
Tension afterwards the same.
Then spray water over the chain. Tension it again, do a ride again.
Wooha chain hangs like it was a ride around the world.
That's because dry rust has alot more strength than wet rust.
Take a piece of cotton.
Rub over a rusted tool.
You see a little brown on the cotton.
Now make the cotton wet, and rub again.
It's like all the rust comes off.
That explains why one can think a rusty chain has half its life left, based on tensioner position, hanging, whatever.
To ride a week without retensionings / derailer position changes.
To then at first ride in the rain, oh what happened my chain got worn to its max the last 10 minutes.
An electrical bike guy at work told me once that he had his chain cleaned by a guy that had some cleaning machine.
When he mounted it back, his derailer suddenly sat at its end and he had to bin it and put a new.
The plus is that his bin stayed clean. ;)
That's the why of the so many different stories about lubrication out there.
It's all <censored> except Sheldon's way, which costs you 10-20 new chains, unless you can book it as ukraine support. ;)
That's why they sell motorcycle chains with sealings. These keep the lubricating agent, and worn off particles, inside, and hold water, dirt, and new oil, outside.
UGH!
presta
Wiping a chain with a rag only removes the grit from the outer surfaces where it does no harm anyway, it doesn't remove it from the capillaries where it's trapped, and that's what's wearing the chain. The same applies to cleaning bikes in general, most of what you're removing is the stuff that's not trapped between moving parts, and not doing any harm.
I used to wash & oil my chain four times a year, with an occasional extra lube if it got rained on for any length of time, and the mileages I got from my chains seem to compare favourably with figures others bandy around on forums.
My Horizon is 24 years old next month, so that makes it by far the oldest bike I've had, and the only one that's done tens of thousands of miles in all conditions and all weathers, but it's also the only one that's still pretty much in pristine condition, largely because it's the only one that's been kept indoors in the warm and dry all its life.
Think I'll review my current method of dribbling melted lard on the chain.
Marchrider
the best thing I have ever discovered for winter chain maintenance is a heat gun - I think most come with a chain drtying attachment.
hang bike up
wipe sides of the chain with old dirty rag
then use brush to flick away crud on top and bottom of rollers
heat chain up to help evaporate any water
while warm, a drop of oil (sae 40 lawnmower oil does) on each link
warm it again so oil flows inside chain
wipe excess off with cleaner cloth
whole process under 10 minutes, and no matter how wet and salty the roads have been - this tactic seems t be enough for the chain not to go stiff during the night
most folk have no idea what this attachment is for
geocycle
An excellent thread. I’m not as thorough but have a similar cleaning regime to @mickle.
Probably because I leave it too long I do occasionally squirt some degreaser on the rag I use. I’m intrigued by the @annedonnelly sock method and might give that a go, I use an old towel cut into squares. One for the drive chain, one for everything else.
I prefer a light lube and use pro link gold applied through a pipet to the rollers.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
hang bike up
Interesting I use ISO 100 oil, mixed with ISO 15 oil to help it get inside the rollers. Seems to be good for about 700km all weathers.
standard-conversion.pdf
Marchrider
ISO 100 will be a bit thinner than my SAE 30 - but there doesnt seem to be performance spec for any oils at winter riding tempertures 0 to +5c
But I think the important bit here is getting it inside the rollers, dropping anything on the outside of the chain in a cold garage will probably just sit on the outside
my theory with heating it up is; it will be thinner enough to get insdie then when it cools down it can't escape - of course the flaw in that is that it may be too thick to lubricate, even if it is inside
I seem to get reasonable chain life from a minimum of effort and the lawn mower oil is plentiful and cheap
