The badboy is lose
Badboy
The badboy is loose
Hi All
Im very new to cycling having only ever used bicycles when I was younger, as the years pass me by and my job means I spend most of my time sat on my backside (graphic design) I am developing an ample midriff which im keen to lose.
I have setabout doing this today and have provisionaly set up a purchase of a Cannondale Badboy 2009 Disk. I'm not 100% sure on is the ideal frame size as I cant seem to find much info on the net regarding frame sizes from Cannondale. My height is 5'9" with an inside leg of 30", I was thinking the medium would be a suitbale choice but was wondering if anyone could offer any advice please?
B
Badboy
The badboy is loose
Hi All
Coco
Glasgow
You're probably best to try to find one and have a ride on it. You're likely to be on the cusp of the sizes. I'm the same height and this was the case for me.
Coco
Glasgow
B
Badboy
Cheers chaps, should have said... I did take a walk to my local bike shop today in the snow to take a look at one and the frame size they had in was 17", it seemed a touch too small but as I couldnt ride it, it was hard to tell. I have provisionally pulled the trigger on the medium so will wait and see. Really excited though as the overall quality of the bike seemed superb and it was so light :ohmy:
B
Badboy
Cannondale Bad boy Medium has a 17" seat tube, which is the same as my Giant mtb.
I am also 5' 9" 30" and sat in the middle between 17" and 19" frame (Medium and Large in Cannondale speak!).
I think you would fit either, with less or more seat post showing - mine is up as far as it can go. But I would suggest going for the large if it is primarily for road use - your crotch will still easily clear the crossbar.
B
Badboy
Ahhhh, cheers 2loose! If it comes and seems too small then it will have to go back for the larger frame but based on what youve said it might be ok.
B
Badboy
B
Badboy
Again cheers guys, I feel a little better about my decision and cant wait for the snow to clear and the bike to arrive now.
