Thames Loop…
KiterStu
Rickmansworth
KiterStu
KiterStu
Rickmansworth
Has anyone cycled it? I’ve done the bit from Brentford to Kings Langley and now I’m thinking about doing the whole thing over a couple of weeks
T4tomo
Has anyone cycled it? I’ve done the bit from Brentford to Kings Langley but I’m thinking about doing the whole thing over a couple of weeks
is it all tow paths?
I'm familiar with Watford / Ricky road up to King Langley and then up and beyond Tring, which is Ok in some places and rough in others. I haven't ridden it all (as I generally avoid towpaths) but did a few sections on some gravel rides and I've gone over it etc as far up as Leighton Buzz. A lot of it is on google street view as some chap has uploaded it. Its just a grassy path in places....
KiterStu
KiterStu
Rickmansworth
A lot of the bits around Watford and Ricky and further south have been resurfaced over the past few years so they’re pretty good. That’s a good idea tho, I’ll take a look on Google
Juan Kog
permanently grumpy
My suggestion do it during the coarse fishing close season . You won’t have to contend with grumpy anglers with there very expensive tackle spread all over tow path .
The Oxford Canal has a dire towpath. Most of the Thames Path is not legally cyclable. I’d recommend using a bike route planner for bike routes rather than a canal one ;)
KiterStu
KiterStu
Rickmansworth
Dire as in a bit overgrown or completely impassable?
I suppose I could take a machete along if needs be.
I’ve cycled the Thames Path in London between Imperial Wharf and Brentford. Some of that section is off-limits to cyclists but I did it anyway and I didn’t encounter any problems.
figbat
Slippery scientist
Much of the rural Thames path is footpath. There’s a bridlepath section from Goring to Pangbourne but after that it’s footpath again, although there are parallel bridlepaths and other cycle trails that track the river.
T4tomo
to be fair no-one will argue with him if he's carrying a machete
....although I have been approached by a lock key wielding septuagenarian yelling "dismount, dismount" on a tow path that was cycling allowed. the conversation went something like:
"you do realise were allowed to cycle on here?"
"yes but you putting my life in danger"
"er you're the one waving a heavy metal lock key around..."
