I just bought a second hand Tern Link, 3-Speed hub version, ca 2016 model.
The bike does not seem to have run a lot of milage.
I uses it on my way to work, in the commuter train. I only fold the main chassis, in fact there is enough space...
(But enough to present the teckit inspector a folded bike to avoid an extra ticket for the bike)
However, I found that the foldable stem has a lot of play.
Observations:
-If I push the lock handle firmly against the stem, there is no play.
(makeshift measure: applying a velcro strap over the handle, forcing it against the stem...)
-The spring inside, visible when folding the stem down, was badly mangled - finally I broke it.
My feeling is that a new spring will solve the problem, is that correct?
Did you find other week spots on the Link series?
Observations:
