Shut Up Legs
Down Under Member
Can any of you tell me what (if any) is the correct term for the type of middle chain ring (in a triple chain ring configuration) which has 10 bolt circles, i.e. onto which the small chain ring is bolted? Also, what is the term for the one with only 5 bolt circles?
I've been doing various internet searches, and I've found out about type A, B and D chain rings, however these terms seem to be used purely to indicate compatibility between large, middle and small chain rings. I couldn't find any terms to distinguish between the middle chain rings with 5 bolt circles, and those with 10.
Here's an example of the chain ring with 10 bolt circles, from SJS Cycles:
http://www.sjscycles.co.uk/shimano-...hainring-d-type-silver-39t-prod27799/?geoc=au
and one with only 5 bolt circles, from CRC:
http://www.chainreactioncycles.com/au/en/shimano-sora-fc3403-triple-chainring/rp-prod38171
