tension in sholders?
alci4
birmingham
ok so i am mostly talking to the road bike riders here as i don't get it on the mountain bike
does anyone get tension in their shoulders when they are riding a while I.E. 20+ miles
I am wondering if i am riding in the wrong stance i tend to have my arms straight and i tend to lean and tense up.
just wondering if i should be putting any weight on the bars at all or just holding them.
i find that if i bend my arms while cycling my shoulders automatically untense.
sorry if this does not make much sense
albion
Gateshead
Happens to me occasionally.
But what I do recall, is that when I moved my seat forwards a lot of weight went off my arms making for much less tension.
albion
Gateshead
I normally ride a road bike converted to flat bar c/w a granny gear system.
My stem/reach seems low which I like with it becoming overall, comfortable.
I often do very long rides and before the seat move I did have the feeling of my arms being 'very straight'. So straight that I would often adjust my hands/wrists to add arm length. I still do that , just very rarely now that I have a naturally lower weight on the bars..
migrantwing
As @cyberknight mentions, it may be your reach. It's amazing what as little as a few millimetres difference can do.
I had a very good deal on my bike, which I got at the beginning of 2012. It was the previous years model so there was a good 25% off the RRP and paid around £800 instead of £1200+. In hindsight, I always wondered if I should have gone for the next frame size down (54cm as opposed to 56cm) which I believe would have been better for me...but this would have meant that the headtube and steerer tube would have been shorter, meaning that I wouldn't have much room for tweaking my position on the bike regards comfort. This made me realise that I did indeed get the right size frame, I just fixed my problem by fitting a shorter stem (from 100mm to 90mm) and then my neck and shoulder pain eased up a lot. I still get it occasionally, but that's because I've slammed my stem. If I had gone for the next frame size up (58cm) it would have been too big and any standover height at all, even with a sloping top tube, would have been non existent. The basics of buying a bike is that you buy a frame that suits you, then tweak it with stems, bars, adding spacers, taking away spacers until it feels right. You could call it a custom fit in theory.
