Andy clarke
- Stockbridge
Up for swap against mountain bike and possible cash my way less than 250 miles
sizesLarge 55.5cm, Medium 53cm, Small 50cm, x-Large 57.5cm (Frame size guide)
coloursRaw carbon
frame typeRigid
frame materialCarbon Fibre (The quick guide to carbon fibre)
gears20 speed
wheel size700C
brakesetR580
chainsetSRAM S350 compact 50x34T
front derailleurSRAM Rival
rear derailleurSRAM Rival
shiftersSRAM Rival
cassetteShimano CS-5600 12-25T
wheelsRitchey Pro 20H front, 24H rear
Frame
frame materialCarbon fibre
frame descriptionUltralight unidirectional T700 carbon fibre monocoque
Braking
brakesetR580
Drive
bottom bracketSRAM GXP
cassette (rear cogs)Shimano CS-5600 12-25T
chainShimano CN-5600
crankSRAM S350 compact 50x34T
pedalsN/A
Gearing
derailleur frontSRAM Rival
derailleur rearSRAM Rival
gears20
shifter(s)SRAM Rival 10 speed
General
handlebarRitchey Comp OS 31.8mm
headsetFSA Orbit integrated cartridge bearing
headset spacersFull carbon 4x5mm, 1x10mm
rigid forksUltralight unidirectional carbon fibre monocoque
saddlecboardman, Cro-Mo rails
seat postRitchey Comp 31.6mm
stemRitchey Comp OS 31.8mm
weight17.6 lbs
Wheels
hubsSealed bearings
rimsRitchey Pro 20H front, 24H rear
spokesStainless steel double butted black
More pictures are available this bike is a large or £650 ovno or swap for an equal value alloy framed road bike
1 minute agoEditReport
TopReply
coloursRaw carbon
frame typeRigid
gears20 speed
wheel size700C
brakesetR580
shiftersSRAM Rival
Frame
Braking
brakesetR580
Drive
pedalsN/A
Gearing
gears20
General
weight17.6 lbs
Wheels
hubsSealed bearings
TopReply
