tacx flow turbo
poynedexter
for anyone who would fancy a power meter feature on a turbo for training, i bought one of these and highly recommend it.
after a period of feeling like i was training riding racing but not making any progress, finally this turbo has allowed me to see progreess
it cost me £180 from decatlon and has changed my approach to training in the last 3 months. i use it along with a heart rate monitor. it allows me to define my FTP, set my training zones, and the bit i like, it gives me numbers to confirm if i'm tired, rested, making progress or not.
i've no idea if the power numbers are accurate or not, but they seem repeatable and consistant. i know 3 other people with the same turbo and ive tried theirs too. the numbers from theirs are very similar to mine.
i took some advice locally, checked out british cycling's power zone calculator and got to work. i've been doing long road miles at no great intensity, lots of sweet spot turbo work with various interval sessions.
i do the same turbo warmup every time, ramping up the watts and monitoring my heart rate. this has been a great way to track progress. after about 6 weeks of fairly static watts, ive seen a 20- 30 watts increase at 135 bpm and an increase of 12 watts in FTP after about 12 weeks. i'm due another FTP test soon and feel its moved again perhaps by a further 5-10 watts. i have no idea if these numbers are typical or not, but they are a measure of change. until i bought this non smart turbo, i had no gauge apart from feel.
i can feel the difference on the road for sure and my race performance is never better, but the biggest thing is having some data to back it up. knowing that training is actually working. i've had a couple of days when my power is down at particular markers, and i've just stepped off and rested till the next day. having tired legs and just pounding away doesnt happen any more. i use my HRM and PM as my gauge.
it might not be a £500+ PM but imho its a fantastic tool and for anyone wanting to measure progress its been money well spent.
Norry1
Warwick
Bumping this as I was interested in people's replies,,,,,,,,,,,
BSRU
A Human Being
Swindon
Having a consistent and reliable power meter is a big help in monitoring progress or lack of.
TrainingPeaks, Golden Cheetah etc are very useful tools for use with power.
I use mine to measure my aerobic fitness, checking the aerobic drift/decoupling after greater than two hour power zone 2 sessions.
T.M.H.N.E.T
Northern Ireland
I've had the older yellow Flow for a couple of years(bought for the pricely sum of £60) generally use the same bike, same turbo tyre + pressure and all in the same paincave. Accurate or not, that thing is more than capable of leaving me jelly legged, and it does regularly enough :laugh:
Citius
Sounds useful, but it is still possible to track changes/improvements without measuring power - just not as readily as you can with a PM..
poynedexter
poynedexter
with so many threads on here about going faster, cadence, going uphill faster, sprinting faster, doing squats!!!. this is a relatively cheap turbo which can give you live feedback.
want to know how cadence variation feels at a fixed power/ speed/ intensity? set you watts at 300 and try 80 rpm. then try 100 rpm. feel the difference? oh yes.
its not an interactive device, but thats not really impt to me. all you need is repeatable numbers to focus on. and a regular ftp test.
want to get strong by doing squats? use this turbo to measure the difference it will make, or the harm you will do.
i sort of took a break from open racing and told myself i would only return if the numbers improved. now i can see the numbers rising and it has given me a target to reach for 2016.
i think they were £250 a while back, and decathlon were doing click and collect for about £170. bargain!
Citius
Agreed - but progress can also be effectively tracked by other means, like aerobic limit tests, for example. Speed on the turbo can also be a useful proxy for power, assuming the setup is consistent.
Citius
Being magnetic how loud is the trainer compared to a liquid one?
Magnetic resistance creates no additional noise - unless you are confusing it with a fan?
