I've just got my old mountain bike back from my dad to use for commuting but the gearing is too low.
It's an old dyna-tech running stx-rc and is quite considerably lighter than my current £100 falcon but it has a compact chainset with 22-32-42 chain rings. I really want the gearing to make use of the downhill sections on my commute. I was hoping to use the 28-38-48 chainset from my falcon but was stopped by the different spindle length. The bottom bracket is 112.5mm on the dyna-tech where as the falcons cup and bearing setup is 122.5.
Can anyone suggest a cheap crank i could use instead that would work with the shorter spindle? I don't want to replace the bottom bracket as it works well and i don't have the tool for it. There is plenty of room for a 28t chain ring if it was in the same position as the one on the stx-rc crank. The falcons chain rings stick in a long way only because of the long cheap old spindle. It was a 15 speed bike so i can't see why it have the chain ring in so far and be mounted out so far!! I thought 122mm spindles were for 24 and 27 speed bikes.
I don't have the time to look around on-line or drop into a shop which is why i've come here.
I'm on a budget and already have to replace the cassette due to the highest gear being shot and the chain is way past it's best so riveted cranks are fine as long as they will go on and line up. i tend to change gear rarely and in plenty of time so shifting performance is not high on my list.
Thanks.
Thanks.
