SWAP PROSTOP 8" DISC SETUP
ChrisCrc
Essex, UK
Hi all
I have for SWAP a 9" PRO-STOP DISC SETUP
This is a semi Hydraulic setup which includes a Bulls-eye Suspension Hub on a Mavic Singletrack rim, a 9" 6 Hole Floating disc and a PRO-STOP Hydraulic Caliper which is operated by cable and a bleeding kit, all fittings and fixtures are included. Also included is a Clamp to attach the Caliper to the fork Leg. This setup is ideal for forks with the Protruding front wheel lugs LIKE THESE
You can STOP on a sixpence with this, and i have seen a few people go over the top by thinking they know it all ( as we all do sometimes:biggrin:)
I have owned this setup since the early 90"s and the Mavic rim is a straight as the day it was bought and has never been trued ( a true testament to the maker MAVIC of quality rims/wheels). this was £390 retail (without the wheel ) when it was purchased.
Rather than sell it I would like to swap it....
What i'm after is a complete front wheel with a 6 hole Disc Hub preferably shimmano or other good make ( no cheap ones that will buckle or crack on the first ride)
OR A FRONT MAGURA HYDRAULIC RIM BRAKE COMPLETE with the Lever & pads ect.
There are no faults with is setup and it is slightly grubby (dirty) in places.
If you have a spare front disc wheel or a Spare MAGURA RIM BRAKE and fancy a SWAP then please give me a shout......I am based in Benfleet in Essex and i can either post it out to you by 1-2 day Courier or Pickup from me is also welcome.
thanks for looking
Chris
