MacB
- Farnborough, Hampshire
Folks, posted this on YACF as well, just scrounging info again and displaying my general ignorance, as usual all help grovellingly appreciated:-
Folks, following the advice received I've ordered the Surly frame in the 60cm size, now I just need to add all the other bits. I'm a big guy who's heavy on the pedals and wheels(spoke repair again tomorrow!!!), currently doing about 140miles a week and it's rising, full commute will be 200 per week. So super lightweight is very much secondary to longer lasting/robust, I'll have a seond bike for non-commuting stuff. Hoping I can get some feedback from those that have dealt with this frame. I know it's a long post, just didn't want to post up lot's of different threads:-
Front Wheel - I want to get this with Mavic A719 rims in black to match the rear wheel. I'm musing about whether I want a dynamo hub and, if so, should I go for the Schmidt. I have seen complete wheels, built around the shimano NX32 QR dyno hub, for about £90. Then where to get wheel built?
Frame Protection - I've seen reference to the idea that the inside of the frame should be sealed/protected before build. What does this involve and who does it?
Brakes - I have these brakes - Merlin Cycles - - - it's a Deore V brake kit, will they fit the Surly ok?
Bottom Bracket - needs a 68mm English, threaded 1.37x24t???, the chainline from the Sram hub should be 48.9mm, according to their specs. I really seem to get lost when I start looking at BB's, what specs should I be aiming at?
Cranks/Chainring - I get that they need to match the BB and the chainline but then I'm lost. Do you buy a single specific set, or any old ones and remove/re-space chainrings?
Chain - what sort do I need, size to chainring/cog? powerlink/Sram?
Seatpost - need a 27.2mm seatpost, do I need to go steel, or should I go alu or carbon?
Thinks that's it, I'm good with the rest, appreciate the help....thanks....Al
