Cyclopathic
- Leicester.
I've got a suntour freewheel hub with the two notch fitting. I've tried to get it off but only succeeded in stripping the prongs from my tool. As far as I can tell I went about the job in the correct fashion. I located the tool in the notches and secured it with the wheel nut leaving some play to be taken up when it undid.
I put the tool in my biggest, most secure vice and began to undo in the usual way.
It was almighty tight and not giving at all so I was encouraged when I felt some give. Unfortunately it was the tool breaking.
Is it just a shoddy tool or is there something I'm missing. I was undoing it in the conventional direction for undoing.
I slightly heated the whole affair and dowsed it all with penetrating oil and have left it until I can get another tool.
Do I just need more brute force?
