Yep, just didn't put it very well.If it's an ultra6 then no, but I think otherwise usually yes if the wheel is dished for 7 - I think you can tell if there's space between the end of the sprockets and the frame (I think that's what @raleighnut is saying). Both regular 6 and 7 are 126mm OLN IIRC.
It depends if you have room on the hub.
We have to assume the wheel is not dished for 7, though.yes if the wheel is dished for 7
I think it's whether the hub is a 5-6 or a 6-7, I've shuffled axle spacers around on hubs to get clearance but it either means getting the wheel 're-dished' or as in my case ('s) rebuilding the hubs to get new rims laced on ( I love Maillard 'wide flange' hubs)We have to assume the wheel is not dished for 7, though.
Sheldon offers dimensions to inform any decision. The 7sp block would be 2.4mm wider. This would not fit on my 6sp wheel: it would screw on but not fit between the dropouts.
Why do we? It might be. My 5 speed wheel took a regular 6... although I had to reshuffle a rack-mounting bolt to clear the chain.We have to assume the wheel is not dished for 7, though.
Well you don't have to, but most trying to give good advice will, because the OP says:Why do we [have to assume the wheel is not dished for a 7]?
Why would an old wheel be dished for 7sp yet have a 6sp fitted?At the moment I have a 6 sp 14-24 screw on block fitted
Well, why would an old wheel be ready for 6sp yet have a 5sp fitted? Yet that's what I had, the rear dropouts were 126mm (6sp) not 120mm (5sp or old SA AW) and I understand that's not so unusual. Looking at the thing is probably the best way.Why would an old wheel be dished for 7sp yet have a 6sp fitted?
Most old style 5sp blocks can be successfully replaced by a regular 6sp as the distance between the small sprocket and the dropout allows this - as you discovered (reported above).
Other way round: if you had ultra 6 already, a 7 speed probably wouldn't be an option. Ultra 6 fits in the space of a regular 5 speed. http://www.sheldonbrown.com/gloss_u-v.html#ultraJust out of interest why would an Ultra 6 not fit? How can I tell the difference between an Ultra and another Suntour 6 sp.
The OP's freewheel has a 6sp fitted.why would an old wheel be ready for 6sp yet have a 5sp fitted?
