GoodLifeSpud
Hello all
New to these boards and am hoping to dip my toe into a spot of bike restoration/salvation.
I recently aquired the above bike for a very small sum in order to get me to and from the station. It was intened just to be a test to see whether i get on with cycling as part of my commute, but as i'm now decided and have got a road bike for my daily ride I am thinking about giving the Sun Solo a makeover/restoration.
So far I've looked at the Sheldon Brown site and have read some bits and bobs about bike maintenance (but mostly about newer bikes). I'm looking at this as a first time restoration project so it will no doubt be a steep learning curve. But stuck behind a desk all day i'm keen to learn.
I have a vague idea of what things i need to attend to. So any thoughts or pointers or suggested reading/viewing would be much appreciated.
I'll add pics when i get chance. So here it goes?:
- the wheels are fairly rusty, buckled and the rims are pitted/far from smooth. The tyres say 26 inch x 1 1/4. If the tyres match the wheel size, i know the wheels are hard to source. Or they seem to be. How can i be certain of the wheel size? Where should i be measuring from/to. I know i will need to get the back wheel built to use the existing hub. And that imperial tyres/wheels won't match decimalised equivalents.
- the brakes consist of long side pull callipers. The brake cable is a fixed length with nipples at both ends; both of which pull the lever and calliper. So the cables can't be shortened. I know the cables are almost impossible to replace, so is there a way of using the existing callipers but with different leavers and brake cables, or is it possible to find new brake callipers that will reach the rims and not rely on a fixed length cable? Standard callipers in shops like Evans dont appear to be the same length.
I have been told a bigger wheel and shorter callipers would not work. If I'm to look for new ones what measurements should i be trying to look for.
- The sheldon brown site seems to suggest some other parts (that i have not yet looked at) e.g the bottom bracket might also prove difficult to find as only raleigh did things in a particular way at that time. Is this likely? ?
- If i were to get the frame resprayed how far would i need to strip the bike down?
Thanks in advance for looking at all of that.
Dan
Dan
