Stupid question re hubs and rims
Not been on here for a while, but thanks to those that offered advice with the restoration of my Sun Solo. The frame is currently being re-sprayed and I am hoping to be able to start putting it back together soon. One of the questions I asked back then was to do with wheel size, going from 26 1 1/4 to something bigger in circumfrance. I'm relativley confident that 700Cs would fit when I come to purchase some new wheels but I'd like to try and be able to make use of the 4 speed SA hub. This has 20 spoke holes each side, but most of the 700C rims I have seen in the obvious places on-line have 32 holes/36 in a couple of instances.
Does this prevent me from making use of the hub in a 700C wheel?
I said it was a stupid question, but am a firm believer in the thought that it's only an obvous answer if you know what it is :-)
compo
Harlow
The rims are available, just a matter of finding a wheel builder to do the job for you, unless you are into the black art.
http://www.tandems.co.uk/m11b0s41p497/MAVIC-T-519-40-hole-700c-tandem-rim-silver
