swiftylee
Wilier Cento1 SR with Full electronic Ultegra Di2 Custom Built
Size is an XL which is a 57cm top tube
The battery is internal - housed in the seat post. Charging it is easy through the mini USB port of the trim unit under the stem. Perfect gear changes
RRP is £3500 and it's upgraded with Specialized Carbon bars & Toupe saddle. Overall it cost in excess of £3750 when new.
Also comes with
1) ears for a carbon rail saddle
2)Spare dropout & frame cover/guide for mechanical gearing if you ever wanted to change it
3) spare B/B.
This would typically suit some-one between 183-195cm
This would suit a rider with a saddle height from 680mm to 830mm from centre of bottom bracket (up to a 35/36" inside leg)
The bike is like new, no wear on drive chain, even the tyres have not been ridden on
With a good set of wheels this is a sub 17lb build, comfy enough to ride all day or pop a number on your back and race, not much will keep up with you
Reviews: (4.5 & 5 star reviews)
http://www.competitivecyclist.com/wilier-cento1-sr-frame
http://www.bikeradar.com/road/gear/...-wilier-bikes-cento1sr-custom-build-13-47093/
http://pelotonmagazine.com/tested/wilier-cento1-sr-review/
http://www.cyclingweekly.co.uk/reviews/road-bikes/wilier-cento1sr
Also comes with
3) spare B/B.
