balloburn
- Perthshire
I think my spd mtb cleats are getting a bit worn down. But for the life of me, I can't loosen the buggers off my shoes. They have been on for about 2 years. Any tips?
When the allen socket has been drilled out to the same size as the bolt, the head falls off and there's no longer anything to hold the old cleat on.balloburn said:Drilling? Who does that work??
...which is no fun.andrew_s said:When the allen socket has been drilled out to the same size as the bolt, the head falls off and there's no longer anything to hold the old cleat on.
You are left with a threaded bolt end sticking about 5mm up above the bottom of the shoe. You should be able to clamp on a pair of mole grips tightly enough to just undo this.
much better to have greased the bolts properly in the first place, but in the absence of a time machine, needs must...Chuffy said:...which is no fun.
