Due to a transport disaster, I have a bike where the mech hanger can no longer be screwed to the frame, as the hole within the frame has had the thread torn out (the mech hanger was forcibly pulled off the frame). The screw was steel, the frame is scandium allow, and the screw just tore itself out. This means the screw nolonger grips the frame to hold the mech in place.
When the wheel is in place, this is not a problem, as the wheel and thru-bolt holds it all together, but when the wheel is removed, there is nothing to hold the mech and the hanger to the frame. Has anyone had any experience of this and found any decent solutions? Supergluing the hanger in place lasts a couple of months if I am gentle, as the bolt is not needed when the wheel is in place. Maybe a slightly wider screw that might cut a new thread in the frame, or is there anything that can be done by a competent bike builder with a welder? The bike is fine until then back wheel comes off, at which point the rear mech usually detaches itself in a very annoying manor..
