If we are going on about cycle paths and planning - it would be nice if they actually bothered to tell you that there is a cycle path available unless you pass the actual start
Round here there is a dual carriageway with a good 2 way cycle path on the North side - absolutely nothing on the SOuth side indicating it - or how in the name of ann the Gods you are supposed to get to it
AND - when there is a cycle path then it would be nice if "they" could mention it when it finishes - I have seen lots where there is a shared cycle path - nice and wide and plenty of room
Then some time later you realise that is is now rather narrower and then you come across a kerb that is clearly not designed for bikes to use - turns out the cycle path ended a while ago but there was no signs or anything!!!
AND - no - I leave the rest for now - getting a bit ranty!!!!
