Strava - Garmin Edge 200
phil_hg_uk
I am not a member, I am a free man !!!!!!
Plug the Garmin 200 into your pc then goto My Computer and find the Garmin then open the Garmin folder then the New Files folder and put the GPX file in there once that is done disconnect the 200 from the PC. Now start up the 200 and find the course in courses and select and it will convert the file so you can use it.
ianrauk
Tattooed Beat Messiah
Rides Ti2
open the 'new files' folder on the garmin then drag and drop the gpx file into there. The 200 should then convert.
phil_hg_uk
[QUOTE 3232342, member: 45"]That would be great if the stupid Garmin site would work. Classic version recognises the device but won't talk to it. New version won't even recognise it.[/QUOTE]
Assuming you have the GPX file on your computer and you are using windows just goto 'Computer' or 'My Computer' and your garmin 200 should show up as a drive just like a flash drive would, double click on it and look for the New Files folder inside the Garmin folder.
