ajclarkson
- Durham
Hi Everyone,
I've been out cycling quite a bit in January and even braved a couple of pretty windy days in the process. A few rides ago I turned into what seemed like a mild headwind and battled until my legs almost gave out after 10 miles. There were some slight inclines, but certainly nothing over 4% yet my energy was gone within a matter of minutes. I put it down to the wind and the fact I'd probably overdone it a bit on the first 11 miles with a tailwind.
Then I headed out on another familiar route a couple of days later, and in the first 5 miles slight inclines were exhausting my legs. The pedals were just so difficult to turn, even in very low gears on a very shallow incline my legs were aching, and it wasn't a usual hill climbing ache either. The only way I can describe it is like I was trying to turn the cranks through treacle.
I decided to give it a few days off to rule out fatigue or anything, but as it happened so early into my previous ride I was sure it wasn't that. Also nothing has changed in my routine, same breakfast, time of day, similar weather etc. I've since checked the hubs on the wheels were running freely, cleaned all of the groupset, cassette, chain, relubed the chain, checked the brakes weren't rubbing on the wheels. I just set out again this morning, and did a very familiar circle around the local area, exact same problem. Even from the off pedalling on almost flat ground the treacle like resistance was back in the pedals. I changed down to my lowest gear and while they obviously span quite easily then, it wasn't as easy as it should be.
I'm racking my brains now, and wondering could this be a bottom bracket problem? Any hints or tips are very much appreciated. I know a lot of the advice will probably be to take a trip to the LBS, just thought I'd ask to see if its anything I can fix myself .
Cheers
Cheers
