Storing bike against radiator: bad idea?
ontodva
I need to store a spare bike against a central heating radiator, nowhere else for it to go. It will be hot in the cold months. Could that cause a problem with the bike, like drying out bearing grease, hydraulic problems?
ColinJ
Puzzle game procrastinator!
Let the tyre pressures down if you don't fancy hearing them suddenly go BANG!!! :okay:
Johnsco
Old Fettler
If you get the handle bars warm it will keep your hands warm on a winter ride (as long as it's not too long)
si_c
Wirral
I keep my day to day bike in the conservatory against a radiator, leaning with one pedal against it. Never had any problems, the heat doesn't really push more than an inch or so from the radiator so doesn't really heat up the tyres enough to cause a problem with raising the pressure and nothing else is affected by the heat enough to cause any worry.
