Banjo
Fuelled with Jelly Babies
- South Wales
The 2 limit screws, not sure if thats the correct name but i mean the ones that limit the movement of the front derailleur,on my 105 triple keep getting stuck.
I took the derailleur off the bike a few months ago put it in the vice so i could lean on the screwdriver more, got them out cleaned everything then put them back in with a bit of waterproof grease.All worked lovely again.
Just tried to make a small adjustment and the inner one is stuck again .
Any suggestions on what I should use on the threads ?Cant be arsed with having to take it off the bike repeatedly hopefully this time it will be a longer lasting fix.Also would better quality screws be available?
