mgarl10024
- Bristol
Hi all,
I've noticed that my back rim brake seems to be very sticky. When applied, 1 in 4 times either of the pads wont release. If I give them a little nudge with my finger, they spring out, so I don't think it's a spring issue.
Around the rim there is a groove (perhaps a wear marker) which is recessed from the rest of the rim, and I can see that the brake pad has worn with a little bit sticking out to match this groove. My guess is that the brake pad 'slots' in and gets stuck.
I can move the brake pad ever so slightly so that it doesn't slot in, or I could try to file this bit down. Is this something that many of you get? Strikes me that this must be a common problem? What do you do?
Thanks,
MG
Thanks,
MG
