Hiya
Just wanted to gauge opinion on this.
I sanded down my new stem a while ago to make it more carbon friendly but I cannot manage to get an even gap between the top and bottom bolts when torquing it up (stem to steerer).
Ive tried being as precise as possible regarding alternating between the top and bottom in small increments etc etc but always end up with the top bolt having a slightly larger gap than the bottom.
Could it be that my sanding has thinned some areas of the stem which is causing the uneven gaps when torquing up ?.
Im concerned its creating a pinch point but am not sure if that is correct when both bolts are of equal torque !?.
Thanks
Thanks
