bonj said:I thought standard was 25.4 oversize 31.8mm?
slow down said:Depends on manufacturer - Deda is 31.7, but ITM (and most other) is 31.8 OS. I think Cinelli was 26.0 but again ITM is 25.4 (I think)
workers_united said:They are the same size viz. 1.25 inches which equals 31.75mm. It is just that some manufacurers round down the quoted size to 31.7 and others round up to 31.8.
Agreed but you have to make sure that the weight weenies don't think they are getting an advantage by losing that 0.1mm.slow down said:I realise 0.1mm isn't going to be critical
TheDoctor said:MTB standard is 25.4mm. Road is 26mm. Oversize for road and MTB is 37.7mm or 37.8mm - I forget which way round but they're close enough that it doesn't matter.
Having said that, I've used 25.4 mm bars in a road stem, and I'm currently using drop bars in a 25.4 mm stem, so it seems not to be as critical as all that.
bonj said:yep. but you mean 31.7 and 31.8, not 37 ~ ...
