Stem Help
Mallory
Sadly one of my stem bolts actually snapped in half today, so i'm now in need of a new stem.
I currently have a planet x 110mm 6 degree stem.
When seated on the saddle and on the hoods my arms are locked straight and the bars are in alignment with my wheel hubs.
I occasionally get some pain in my shoulders, could this be due ti stem length/rise or does the above seem correct?
Sittingduck
Somewhere flat
Front hub should be obscured by the bars, when you are on the hoods. Arms shouldn't be locked straight though... should have a bit of a bend in them, imho.
Rob3rt
Man or Moose!
Manchester
A snapped bolt doesn't mean you need a new stem. If the other have of that bolt is stuck in the stem, remove it, then just whack a fresh bolt in.
M
Mallory
Not enough bolt showing in order to remove, plus I don't know what damage it could have done to integrity of the threads.
