e-rider
Banned member
- South West
A simple question for someone to answer: How do you remove a star-fangled nut once it's been fitted? (without destroying it or the steerer tube!)
What about the extra weight ??Smokin Joe said:If you have a long enough drift you can push it out through the bottom of the steerer, otherwise just knock it a few Cm further down the tube and forget it.
02GF74 said:^^^ interesting - always seen that carbon steerer must not be fitted with the star-fangled nut.
the arms on the nut are hardened spring steel so if you can get at it from below, you can break the nut with a drift.
but a drill/grinding stone sould do it too.
