simmi
- Auckley, Doncaster
Any 9-speed cassette will work (e.g. BBB/Sram), as long as its shimano-compatible. Your current chain length should be fine, however you should always fit a new chain when you fit a new cassette (due to chain/tooth wear). If you try to use the old chain with a new cassette, you will find that the chain may slip off the teeth.
I got this message back from ribble today in regards to changing my cassette.
Can I conclude from this that all 9 speed cogs and chains are the same pitch, width and form or in short standardised.(not the internal sizes of the cassettes I know they can differ)
If this is the case why is there such a huge difference in price, is it purely to do with the meterials they are made of, or the tempering or coating processes they have had. To I would guess either increase performance or life, or to reduce weight.
I have a Tiagra groupset at the moment and want to change the cassette to a BBB because it has the cogs I want 12-28 and I would like to use a sram chain because I like thespeed links.
To my mechanical brain this dosn't seem ideal but if they are all standardised I guess it makes no difference.
And while I am on the subject why are some cassettes quoted as for MTB are they different or is it that the teeth numbers say 34T are traditionaly not found on road bikes.
Sorry if this goes on a bit but am new to this and want to get to the bottom of it ASAP.
