Rolf Parrish
Regular
Am contemplating a new road bike for the new season. Torn between the 2 setups and am looking for opinions as to which is the better setup Sram Rival or Shimano 105. Experiences would be good please
I've used both - simple answer - there is none in terms of mechanics and shifting smoothness. The decision is probably really about whether you can get on with SRAM's double tap system to change down. Personally I never had a problem but I know others do.Am contemplating a new road bike for the new season. Torn between the 2 setups and am looking for opinions as to which is the better setup Sram Rival or Shimano 105. Experiences would be good please
With Shimano 105 the left shifter tends to break more often than it should.
With Sram Rival the right hand shifter tends to break more often than it should.
Whatever you get - buy new with warranty.
Downshifts are a weak point on the Shimano system in my opinion, there is too much throw shifting with the brake lever and you have the added disadvantage of accidentally squeezing the brakes.
mix and match?With Shimano 105 the left shifter tends to break more often than it should.
