jack smith
- Durham
Am i missing something here? My front mech is a pain in the arse, i can adjust it and it works perfectly in the stand but when i get on the bike it wont shift unless i stop pedaling push the elver right over then slowly move the pedals for it to change from the small to big ring, also it has a trim feature but only on the downshift, there are three clicks but you need to go all the wqy over to what should be the big chainring first before you can trim down so its useless if your trying to be in the small front ring and small rear cogs!! Have i missed something here?
Also my rear is annoying me now its not very smooth changing into the smaller cogs but is like butter going into the larger ones, no matter how much i use the barrel adjuster its the same, its also been skipping about like mad for the past week or so for no apparent reason, also its made for up to a 28t cassette which i run but it seems to bump around and grind abit when it is in the 28t even when the screw is all the way in so the hanger has the most amount of space when in that cog, its being out done by the shimano tourney on my £70 mtb here and its irritating me, anyone got any ideas?
