Squeaky Disc Brakes
Glasgow44
Hi there
What causes disc brakes to be squeaky? My disc brakes on the front squeak; the squeak only happens when I come to a complete stop (they don't squeak while I'm in the process of braking)
What could cause this?
Thanks in advance
SpokeyDokey
69, & my GP says I will officially be old at 70!
Give the search function a shot - loads of threads full of advice on the site.
Hi there
Thanks in advance
What brakes? What pads? When last adjusted?
Jody
Stubborn git
If it's doing your head in and you haven't touched the brakes in 2 years it might be worth sticking some new pads in and give the discs a thorough clean.
G
Glasgow44
Is it easy to put in new pads? I'm not very good at stuff like this but if its easy enough, I would give it a go
Threevok
Growing old disgracefully
South Wales
Saves you buying a bell 🙂
This is actually true. I love riding my One One Inbred in the wet, because it has sintered pads that squeel like hell. Excellent for letting dog walkers (and even wired up joggers) know you are comming.
The Virtue however has organic pads which never squeel. I have to rely on vocal warnigs (and my Hope hub) to let others know I am comming
Kbrook
Yes piece of cake, unscrew the pin, remove old pads, push pistons back with plastic tyre lever, inset new pads, replace pin.
Jody
Stubborn git
Really easy.
Remove the pin and the slide the pads out. Use something like a plastic tyre lever (or appropriately covered up screwdriver) to push the piston back into the calipers. Be careful as these are usually ceramic and will crack if mistreated. Drop new pads in. Re-insert the pin and then pump the brakes a couple of times to bring the pistons back in.
2-3 minute job
You might need to eyeball the pad gap to make sure you can see daylight either side and they aren't contacting.
