I need to change the chainset on my Giant FCR and I'm thinking about changing it to a Sora 9 speed double. The problem is that it's currently fitted with a square taper bottom bracket (for an FSA Vero chainset). In order to fit the Sora chainset this will have to be changed to a Hollowtech BB.
Has anyone done this already? If so I'd appreciate any insights you may have gained along the way for example what components did you use?
The FCR has the same chainset as the Defy if that helps.
Thanks.
Thanks.
