XC26
In the last few years I've had several instances in which a brand new square taper crank slides too far onto the BB axle with the result that the retaining bolt is flush with the end of the BB axle and the crank arm can not be tightened up sufficiently. This has occurred on newly purchased bikes and usually on either the left or the right crank arm but not both - it's not a JIS vs ISO issue. Usually, one crank arm is a perfect fit and the other slides on too far. I've even noticed it with a manufacturer-paired crankset and BB. Has anyone else come across this? Is it poor quality control? The components in question are branded from respectable manufacturers.
