Spot of play in the front wheel
Dec66
A gentlemanly pootler, these days
West Wickham
I seem to have a spot of play in my front wheel, with QR level as tight as it'll go without the need for a tool to lever it.
It's probably a couple of mills at the rim, either side. Indiscernable when riding, but you can wiggle it slightly with fingers pinched on the tyre.
At what point do I start worrying?
Nibor
Bewildered
Accrington
I would get it checked out now if it is a loose ball hub your hub may be shot.
Dec66
Dec66
West Wickham
No need to worry. Merely adjust the cones. What type of hub is it?
Christ knows. Whatever B'Twin use on their standard wheelset for a Triban 500SE.
I'll have a nibble at it tonight. Noticed it yesterday when I swapped the front brake blocks to the back.
Loch side.
Well, ask him. It is important to know because there are two broad types of hub the the diagnosis and repair is different. We need to know if it is a cup-and-cone hub or a cartridge bearing hub. A photo should suffice.
ChrisEyles
Devon
@Yellow Saddle's got it - if it's a cup and cone hub you just nip up the nut on the outside of the hub a touch. If the wheel then feels notchy or doesn't turn as freely as before after tightening up the Q/R, back it off a touch. If the hubs not too worn it's usually not much of a job to get it so that there's no binding but no play either.
On my ancient MTB wheels there's a bit of lateral play at some points in the turn of the wheel that I can't get rid of without introducing some resistance. It's probably of the order of a mm or two at the rim, and I wouldn't worry about that unless it gets worse.
ChrisEyles
Devon
Errr.. guilty as charged! I'd suggest the OP googles something like "adjusting cup and cone hubs", that might come up with something a little more useful with piccies to show which bits are what.
