Sore Thumb
Having a new wheel built for bikepacking. Son Dynamo on a Stand Flow mk3 26" wheel.
Thought the choice of spoke and nipples would be easy. Always had double butted on brass nipples but looking on sapims web site there seems to be more to it than meets the eye. Now I'm not sure what I should choose.
Ive had a look and there is now different double butted spokes to choose from
http://www.sapim.be/spokes/butted
Super spokes
Laser
D-light
Race
Force
Strong
What to choose??
I always thought that brass was the best choice even though they are heavier. Now reading sapims site regarding aluminium nipples, I'm not so sure.
Brass
Since years brass nipples had been the optimal standard. Brass brings less friction and the nickel plating brings a good corrosion resistance against environmental impact. We advise to use them on all standard wheels.
Aluminium
In the past, aluminum nipples had only one positive argument, the weight. All other features like corrosion resistance, friction, stiffness were specific to brass nipples. This changed in the last years drastically. All our aluminum nipples are now anodized. Salt spray tests showed better results than brass nickel plated nipples. You can choose 7 different colors. We had been able to reduce friction with a special coating. As an effect you don’t need to oil or grease the nipple like you should with the brass version. For the last three years, Sapim has used the 7075 material and have additional strength added by the heat treatment T6. Alloy nipples are now stronger than brass. Aluminum nipples are more expensive but for sure much better than brass. For those who care about weight, special colors and quality, aluminum nipple is advised.
So what to choose.
What would be your suggestions?
This is my bike at the moment
https://flic.kr/p/EfjwZ5
Super spokes
Laser
D-light
Race
Force
Strong
What to choose??
Brass
Aluminium
So what to choose.
