Some very helpful replies, all appreciated thank you
A little more background info may help me explain a little better:
I intend building a lightweight steel road bike from a suitable frame, likely to be either 531 professional or 531 competition (I bought one complete 531c bike which turned out to be too large but provides some useful donor parts - including wheels with a 126mm HG 7 speed hub). From what I've read, both 531c and 531p are unsuitable for cold setting. Hence my wish to optimise the potential of the 7 speed hub.
A 7 speed cassette is 31.9mm overall width, a 9 speed cassette (minus one sprocket and one spacer) is 32.16mm overall width, that's just 0.26mm wider. A little research has told me that using this modified 9 speed cassette will work in practice on the 7 speed hub, giving me 8 sprockets, with the spacing remaining 9 speed compatible. Hence I can use 9 speed STI shifters (or at least the first 8 indexed positions) and indexing
should be perfect.
The reason for my original question is because I know lower end (without the spider) Shimano cassettes can be split. However I'm uncertain about SRAM, I've got an 8 speed SRAM cassette which looks like the sprockets are separate, but I'm not confident I could accurately drill out the pins. So the info about screws rather than rivets (
@Nigelnaturist ) is particularly helpful
However one seller has told me the PG950 has a spider
, but another says it has pins
I hope I've addressed the 7 speed 11-28 cassette suggestion (
@T.M.H.N.E.T), I've already got 9 speed STI's. Should I decide to retain the down-tube shifters then this would be the simplest solution
I guess I'll have to get the SRAM cassette to see what looks possible, providing I don't butcher it I can always use it as a spare for the MTB
