Spline?
pawl
I keep seeing when looking for wheels
spline It is something I have not come across before Explanation would be appreciated
ColinJ
Puzzle game procrastinator!
These are some of @colly's splines...
545129
(They are the ridges that stop the cassette cogs from spinning aimlessly on the freehub.)
The reason that I have a photo of them is because they broke on a forum ride! :laugh:
Essex
Generally, the more splines a hub has, the smoother the take-up as you pedal will be so it will feel smoother. If you imagine a hub with just one spline, it could go through almost a whole revolution before the spline engages and makes the wheel turn. At the other extreme, a hub with 360 splines (they don't exist either) would only rotate a tiny amount before the splines engaged. Hope that makes sense ^_^
raleighnut
You're mixing splines up with pawls (which given the OPs username is apt)
I would think 'spline' in this context refers to 'centrelock disc' as opposed to 6 bolt disc mounts.
rogerzilla
A splined connection, in engineering terms, is just a shaft with longitudinal ridges and a matching part that slides onto it. They are better at transmitting torque than a cottered connection or similar, and are easier to undo than a screwed connection.
Shimano use splines for cassettes and the crank to BB connection (now in its third incarnation; the first one was pretty rubbish as they didn't really understand the way a crank squirms under load, and it tended to loosen and trash itself).
It's not a common word outside mechanical engineering circles; the first time I heard it was indeed in a university mechanical engineering lecture.
  • Like
Reactions: C R
simon.r
Person
Nottingham
To go off on a slight tangent, most e-bike motors use the ISIS spline system in the bottom bracket / crank interface.
Just thought I’d mention it^_^
si_c
Wirral
The ridges on a freehub body and on a centrelock rotor are all technically spines as @rogerzilla notes.
Also worth mentioning is that Shimano 12 speed drivetrains use what they term a microspline freehub body - where the ridges are narrower and smaller than on a more traditional freehub. This could also be the spline that @pawl is seeing mentioned - particularly if looking at MTB wheels.
rrarider
Liverpool
Well, I thought that it was but I accept that even with the benefit of the Oxford English Dictionary, a person would struggle to find a definition that made sense.
Perhaps I belong to the generation that struggled to get the the splines on a gearbox first-motion shaft engaged with the driven plate of a clutch when replacing the whole clutch in the 1970s. I think that DIY car maintenance has become more difficult as cars got more complicated and is now a lost art/science to new motorists.
raleighnut
Having trouble there is often down to the clutch plate being misaligned to the spigot shaft bush, the answer is to quote Arkwright "jer Jer Jiggle it a bit"
rogerzilla
I thought it was also the sleazy promoter from "The Blues Brothers" but I now see he was Maury Sline.
rrarider
Liverpool
The proper way was with a clutch alignment too to centre the plate on the flywheel, which cheapskates like me made out of a length of broom handle with tape wrapped round it.
