dudigrinfeld
I wanted to ask regarding the adjusting float. Which wrench key are you using to turn the 2 adjusting screws on the side of the cleats?
Also is there any way to adjust the attached / reengage level of the pedal to the cleat or it is a fix things (i mean how easy or hard is to release or attaché the pedal to cleat)
Thanks for all comments.
I am here: http://tapatalk.com/map.php?lchdmo
