Right, in the poor, wet weather that seems to have bedevilled us all year, I do laps of a 3.5 mile loop near our house. That way, if the weather gets really bad, I'm not too far from home. Anyway, I'm lucky that this loop is quiet, scenic and hilly. Here's my question:
There's one section where there is a left-hand turn slightly tighter than right-angles at the bottom of a long, straight, fast descent on which it's possible to reach up to 70 KPH. What's the best technique for negotiating this turn bearing in mind I want the fastest possible lap time on each loop?
I've tried slowing right down and turning tight on, going less slowly and giving it a wider turn and even cutting tight across almost touching the corner itself and going wide on the road I'm turning on to (this isn't advisable at busier times). The road I turn on to is flat for a couple of hundred metres before a climb so I need as much momentum from the descent at this point. In the panel's expert opinion, what's the best technique at this corner?
