Specialized allez sport Axis Sport 700c spoke size
speedosteve
Hi,
Does anyone happen to know the spoke size for an Axis sport 700c rim that comes as standard on a specialized allez sport 2021 model. I tried to measure it but the end is broken off. It seems to be 27.7cm. I get the feeling I'm going to need a few of these spokes soon!
Thanks in advance. So glad I found this forum.
Steve
Loch side.
Unless someone googles this for you, you have zero chance of anyone answering that off the cuff. We just don't keep stuff like that in our memory. If yiou have the broken spoke, you can easily extrapolate just by looking at adjacent spokes and doing a bit of fiddly measurement. A photo or two should help most of us to estimate the length given the 277mm remaining section.
If the head has broken off, your new spoke should be 277mm. If the thread broke off the new one will be approximately 277 + 9mm, depending on how much thread is left.
Another alternative is to just calculate the length from first principles, using a spoke calculator. You'll need to specify the rim, the hub and the number of crosses.
