I was looking into cyclo-cross bikes and read that its quite a common thing with cantilever brakes (so i guess you dont have the disc version?).
From memory its something like.. when you brake the fork flexes backwards which is normal, but on canti brakes the flex tightens the brake cable and makes the bike brake harder and harder, until it slips which unflexes the fork then the pads bite again, bend the fork, but much faster so its like an on/off thing.
I recall it being common enough that it happens a lot on a lot of different cyclocross bikes because of the canti brakes and will probably be allover a google search. Im not sure that there was a good solution, but if youre clever with levers and angles i think you can reduce it by doing something with the brake cables so that the flex induced tightening has less of an effect on the brakes, maybe by lengthening the horizontal cable. Check google though (or other replies here), im not talking from first hand experience, just from reading about cyclocross bikes.
