confusedcyclist
The dealer manual for my Deore XT FH-M8110 rear hub is calling for Special grease (Seal Grease for Freehub) and Premium Grease. I sometimes appreciate proprietary consumables are unavoidable, like with hydraulic fluid, but I don't normally buy into this with grease, as it's usually just a way to sell own brand consumables.
The manual specifically states use with other types of grease, or mixing of grease 'may' cause malfunction of the freehub. Just for context, I am trying to undo a malfunction caused by the shop that I bought my bike from. They re-greased it under warranty when the hub started creaking after a few hundred miles of fair weather riding. When I got the bike back, I noticed the creaking had been solved, but now the freehub must have some resistance as the cranks and chain spin without my pedalling them when coasting, and occasionally there is a horrid grinding sound coming from the hub. I suspect it is the freewheel, but can't say so categorically, I have tried to loosen the locking nuts so there is a touch of play in the hub as I understand is ideal, it seemed a little too tight by my own experience, but the issue persists. I suspect the freehub has been packed with too much grease, but could it be the shop used the wrong kind of grease?
Shimano would say use their premium and special seal grease, because it helps them sell two of their propriety tubs. Does anyone who works in a shop buy into the dealer manual advice? I'm thinking of degreasing and cleaning the freehub, before giving up on the hub entirely and replacing it, so just wanted to hear from some experienced folk on these types of grease. I imagine the premium grease is interchangeable with other brands, but how about the seal grease? Can anyone recommend an alternative to shimano's seal grease?
