Jonathing
- Birmingham
Hi,
I asked this a while ago but no one knew. I have combed the internet looking for an answer with no success but I cannot accept that no one else have ever come across this problem before.
As a result of being a stupendous idiot one of the tension screws on my pedal is currently stuck at the highest tension. The point at which the screw passes through the coil spring is at the end, and possibly off the end, of the threads. Turning the screw doesn't do anything, it barely feels as if the screw is engaging. I cannot work out how to get the thread to reengage, the black Phillips screw on the medial edge of the pedal, which looks like it should play some roll in dismantling the mechanism, is far too stiff to turn.
As I said before, I cannot believe no one else has come across this before. Either that or the solution is so mind numbingly simple that no one has felt the need to write about it. So please, if you know how to solve this do let me know. I know these pedals can be had for twenty quid a set and the hassle and stress this one screw has given me would undoubtedly be worth twenty pounds to be rid of but it seems such a waste and it has become a matter of principle. I shall not be defeated by a screw.
